When I boot up on Pi 3B+ the splash screen appears corrupted - not a big thing, but annoying!
The resolution is set to 1360x768@60Hz (mode 39) as this is the only thing the (old) TV will accept without cutting things off or having black bars.
/usr$ tvservice -s
state 0x12000a [HDMI DMT (39) RGB full 16:9], 1360x768 @ 59.94Hz, progressive
/usr$ tvservice -m CEA
Group CEA has 15 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
mode 6: 720x480 @ 60Hz 4:3, clock:27MHz x2 interlaced
mode 7: 720x480 @ 60Hz 16:9, clock:27MHz x2 interlaced
(native) mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 17: 720x576 @ 50Hz 4:3, clock:27MHz progressive
mode 18: 720x576 @ 50Hz 16:9, clock:27MHz progressive
mode 19: 1280x720 @ 50Hz 16:9, clock:74MHz progressive
mode 20: 1920x1080 @ 50Hz 16:9, clock:74MHz interlaced
mode 21: 720x576 @ 50Hz 4:3, clock:27MHz x2 interlaced
mode 22: 720x576 @ 50Hz 16:9, clock:27MHz x2 interlaced
mode 31: 1920x1080 @ 50Hz 16:9, clock:148MHz progressive
/usr$ tvservice -m Dmt
Group DMT has 8 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
(prefer) mode 39: 1360x768 @ 60Hz 16:9, clock:85MHz progressive
Any thoughts?
