Hi - after the last update, my Vero has gone into a series of random reboots/crashes. After about 2 or 3 in a row, it stabilises enough for me to watch something.
I managed to get into the OSMC app and upload a log here:
https://paste.osmc.tv/huciruyile
This log was created after about 3 reboots in a row
Apparently it doesn’t reveal much. How else should I be capturing the log?
reproduce the issue
Ok - I hope this log provides the answers:
https://paste.osmc.tv/yehobeyeje
It’s not showing much unfortunately. I would try powering the device via a USB-A cable to rule out a problem with the power supply.
So I finally got my hands on a USB-A - USB-A cable and it appears to have fixed the issue. Thanks
This is a temporary solution for testing.
I’d advise replacing the power supply
