Is it possible to install OSMC and a SQL Server all on one box, that will update and share the library across my other devices?
I would still like it to run Kodi so it can update my library as videos are added but it’s main function will be sharing the database across my other devices.
I have searched and found a few threads but nothing detailed that shows it is a 100% working solution for I’m looking for, and no detailed steps so nothing else breaks.
OSMC has the June update
If I get this working how would this effect OSMC updates?
Yes, should work fine. It should have no effect on updates.
sudo apt-get install mysql-server
He can also go to My OSMC → Networking → SQL for simpler setup
I already have an sql server on the pi1 but want to move it to my osmc pi as i need the pi1 for another project.
Thanks for letting me know it wont break anything.
How would i handle Kodi updates say the up comming Kryton? Assume just update OSMC as usual which will then update the SQL database?
Should i do apt-get update first?
Always update before any apt commands.
Gotcha what about the database updates hoping i wont have issues once Krypton is released
Update the database server first. This is generally not a problem.
Last question, am i able to store the database on a usb key instead of the SD Card. I’d rather have a portable database should the SD Card fail etc.
