I’ve been using my OSMC pi as a squeezebox endpoint (running squeezelite). Ever since upgrading to the November 2015 release (VERSION_ID 2015.11-2), squeezelite can no longer find a sound card:
osmc@hasan:~$ squeezelite -l
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
My other pi, the October 2015 release (VERSION_ID 20154.10-1) has the following:
osmc@heller:~$ squeezelite -l
Output devices:
default:CARD=ALSA - bcm2835 ALSA, bcm2835 ALSA - Default Audio Device
sysdefault:CARD=ALSA - bcm2835 ALSA, bcm2835 ALSA - Default Audio Device
dmix:CARD=ALSA,DEV=0 - bcm2835 ALSA, bcm2835 ALSA - Direct sample mixing device
dmix:CARD=ALSA,DEV=1 - bcm2835 ALSA, bcm2835 IEC958/HDMI - Direct sample mixing device
dsnoop:CARD=ALSA,DEV=0 - bcm2835 ALSA, bcm2835 ALSA - Direct sample snooping device
dsnoop:CARD=ALSA,DEV=1 - bcm2835 ALSA, bcm2835 IEC958/HDMI - Direct sample snooping device
hw:CARD=ALSA,DEV=0 - bcm2835 ALSA, bcm2835 ALSA - Direct hardware device without any conversions
hw:CARD=ALSA,DEV=1 - bcm2835 ALSA, bcm2835 IEC958/HDMI - Direct hardware device without any conversions
plughw:CARD=ALSA,DEV=0 - bcm2835 ALSA, bcm2835 ALSA - Hardware device with all software conversions
plughw:CARD=ALSA,DEV=1 - bcm2835 ALSA, bcm2835 IEC958/HDMI - Hardware device with all software conversions
Any idea how to get this back?
