Hello
Yesterday I connected for the first time from my Win10 PC to the Vero 4k+. I used PowerShell. The first password entry worked without any problems. As recommended in the instructions, I then wanted to change the default password. When I was prompted to enter the desired new password, I suddenly could not enter anything. I tried again a few times but it didn’t work. I didn’t care and continued with the commands given to me by the tech support of the VPN provider and for which I was actually there. Unfortunately, after these inputs sent to me, the LAN connection on the Vero 4k+ did not work anymore and I could not get on the box via ssh either, because now the first password input did not work either. I can’t write a single character on the password line.
Since I had problems with the VPN lately anyway etc. I decided today to reinstall OSMC completely. I made myself a USB stick with the latest Vero 4k+ img and installed OSMC, worked wonderfully and the LAN connection now works again. But when I log in via PowerShell there is still the problem that no more input is possible once I was asked to enter the password.
Could someone explain to me why this problem occurred and how I can fix it? Thanks a lot!
Regards
David
But when I had to enter the password for the first time, it was still visible with certainty ****. Whatever, thank you! Problem solved.
