Hi,thank you for your response.
I’ve set the config setting and confirmed it’s running as requested, I’ve got a Pi 1 Model B
needed to restart the pi sudo reboot rather than just the mediacenter sudo restart mediacenter to get it to take effect. will see how it goes and post back when it’s been used for a bit again (:
So you would leave your existing dtoverlay line(s) in place and just add dtoverlay=sdhost as a separate line. Replacing lirc-rpi with sdhost would not work - they are two unrelated settings.
Hi, nope, still having issues with freezing (sound goes before the image does) but haven’t managed to get a report as it crashes when it happens. It seems to happen randomly, but will try and enable some debugging.
The freeze causes the file not to recognise it’s been playing either (e.g. watch until halfway, it freezes, on reboot the file appears as if it wasn’t watched at all).
Still having the same query: is there a link/howto of how to post a log after a reboot containing the details since the last reboot?
This sounds like you’re describing freezing of the whole Pi? I thought your original message was about freezing of SSH (which is the problem I am having)? Has the SSH freezing part improved at all with dtoverlay=sdhost?
my pi freezes during playback and becomes inaccessible via ssh or a browser
the occurrences seem to have improved a bit, but I’ve used mine fairly infrequently recently, so can’t quite remember.
tried ssh with -v as it hangs after offering my key for the connection, but other than a whole load of details about the key exchange process no actual feedback
I’ve also found ssh -vvv -o LogLevel=DEBUG3Debug SSH at the Maximum Verbosity Level Using alias which I imagine when my pi is actually just frozen doesn’t shed any new light on the issue
I’m not sure if the freeze in ssh comes before the playback freeze, I will try and see if I can find out more
