I would like to ask you all if you there is a (newbee) idiot proof guide to installing PSmisc via SSH?
Can you access SSH only connecting the Vero 4K to the TV thru HDMI?
How does one get to a command prompt to type: “sudo apt-get update”
Or the rest required to install the PSmisc which the Killall + Pidof apps are a part of…
I have had raspberry pi 1-3 and vaguely remember doing this under a windows environment many years ago on the PI, but now also not having any windows or Mac devices available. Only Linux and also new to that. I can’t seem to find any full comprehensive guides on doing this sort of stuff on the Vero 4K.
Until about a month ago, I had Open VPN Manager working as was the case with my PI’s.
A month ago after a Vero Update, I can no longer connect to any VPN. Error messages of the likes: “Killall and Pidof not installed, you need to install them and make sure they are in the command line…blah blah”
I just want my VPN running again…
Maybe I should have not bought 4 of these things, because now I’m having to try and learn once again how to get this thing running.
Any tips and or advice or links to a full (idiot proof) guide to get my VPN working would be appreciated.
Really, I have no idea where to start.
Can I connect the Vero to a Linux PC?
Or can I Install this PSmisc package via a Repository. That would be the easiest way for this mental Neanderthal.
By just opening a terminal window and typing the command you wrote before… should it just automatically find the device if my IP address for the Vero is correct?
I have tried what you suggested and my terminal window is stating:
“No such file or directory”
A little guide for anyone that found themselves in the same dilemma with my ability and technical knowledge.
Guide:
Make sure your Vero is connected to your network (either wired or wirelessly)
Make sure you have SSH enabled in your settings on your Vero.
go to OSMC Settings App on your TV.
select App Store - and make sure SSH is downloaded and installed.
Go to your computer - Linux for me, but Windows & MAC have the program : PUTY
Install Puty
Open puty and connect to your Vero via entering the IP Adress of your Vero. Under Host Name or IP Adress text box
Once a Puty Command window opens.
it will ask you …: Login As?
Type: osmc
Password: osmc
Type command:
Sudo apt-get update - enter
Sudo apt-get install psmisc- enter
It will then download and install PSmisc into your Vero system and will now have the Killall app once again in the command line directory of your Vero.
Allowing you to once again connect thru Open VPN Manager…
