SSL errors on rpi4
Getting SSL errors but only on a few websites, eg
curl “https://audiobookbay.lu
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to audiobookbay.lu:443
The same curl command works perfectly on my Vero V
Is this a known issue with a workaround, or any idea where to start looking, thanks
Could be outdated SSL certs, try staging
Hopefully the issue is now addressed with the following commit:
  1. Login via the command line
  2. Run the following command to add the staging repository:
  3. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  4. Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Is the time correct on your Pi 4?
Good advice, but this will lead to an HTTPS mirror (if I recall correctly), so won’t work.
What version of OSMC are you running on the Pi 4?
I know there is a CloudFlare issue causing SSL issues under Kodi for some time now and it is actively being discussed there.
Linux kodi 5.15.92-1-osmc #1 SMP PREEMPT Tue Jul 25 00:03:42 UTC 2023 aarch64 GNU/Linux
Time is correct
Weird that it’s only affecting some sites, other SSL connections are fine. The Vero V is on the same network and has no SSL issues
Thanks for confirming.
Same servers? Resolving to same IPs?
If so, ping the hostname on a Vero and ping it on a Pi 4 and see if DNS resolves the same.
Hmm, interesting. Ping isn’t working on either machine for this site…
PING audiobookbay.lu (176.97.124.219) 56(84) bytes of data.
— audiobookbay.lu ping statistics —
8 packets transmitted, 0 received, 100% packet loss, time 7312ms
works as expected on Vero V and returns html,
SSL errors on pi4
Both machines resolve to the same IP address
What happens if you use curl -k https://audiobookbay.lu
Same response
osmc@kodi:~$ curl -k https://audiobookbay.lu
Also fails with IP instead of hostname
curl -k https://176.97.124.219
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to 176.97.124.219:443
