Hello,
I am attempting to set up SSL for use with Kore on an Android device, and I’m having some problems. I’ve done the following on a fresh installation of OSMC on a Raspberry Pi 3:
- Created certificates in ~/.kodi/userdata:
openssl req -x509 -nodes -days 365 -newkey rsa:4096 -keyout server.key -out server.pem - Enabled both application control options for remote control from applications on this and other systems (through Settings -> Services -> Control)
- Changed the HTTP server port to 443 (through Settings -> Services -> Control)
- Enabled SSL (through Settings -> Services -> Control)
I’m able to connect using Kore until I enable SSL. Kore disconnects and is unable to reconnect. I am able to connect using a web browser after ignoring the certificate warnings about not having a trusted CA.
I see from the release notes that Kore v2.5.1 added support for self-signed certificates, so I’m not sure if there’s something wrong with my certificate. I tried importing server.pem into my Android device as a user certificate, which didn’t seem to help.
After performing a reboot over SSH (sudo reboot now), the SSL setting disables itself.
Any advice would be greatly appreciated.
