Start Screensaver mode
Hello!
I want the OSMC to automatically start Dias Slideshow with the images in my Picture library (or a customary chosen folder) when the OSMC has been left unattended for a while. As a screensaver (kinda like the chromcast does)
Is there a way to achieve this?
I am running it on my Raspberry Pi 3
I guess this could be the answer
http://kodi.wiki/view/Add-on:Picture_Slideshow_Screensaver
Hi!
Yes, thank you so much for taking the time to reply!
I feel really stupid for having asked the question, since this app comes up on Kodis webpage.
The fault was not totally my own though.
When installing OSMC on Pi, the standard skin wont let you (or at least me) browse any apps, only the ones pre-installed.
You have to change the skin, to view the available apps.
So when i went into “look and feel” the only apps i could see were “Dark” and “Dim”
However, found them, installed it, and works just as i wanted!
Hope someone else can learn from this answer, if they get a “No Apps” error like me :slight_smile:
The default skin also allows you to do that.
Just after enter addons go to install from repository. You might need to go one level up from MyAddons
