Hi, I’m a short time vero user and love it so far.
A few days ago I set up pvr and as soon as I click on a stream the vero crash. I’m using a wlan repeater with dvb c, so I get my TV signal from the network. The repeater generate a m3u Playlist with all the streams. The m3u hase worked fine on my Pi and Chromebox.
Internet stream in a m3u are working but thous lokal stream are killing the vero.
Any help to get this working would be appreciated.
here is the m3u
https://drive.google.com/open?id=1w8kc51nzbwiLyW-Az7o8Uvo9cnBOYpIC
log
https://pastebin.com/JevDZvkq
Hopefully the issue is now addressed.
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
Thank you for the super fast fix Sam!
Its working!
