You can download WinSCP and do it using a PC with no command line knowledge needed
That did the trick. Both profiles seems to be working now. Thanks!
Lol at the difference in speeds from the units when copy/pasting, it was like 30mins from the 4k and then woooooosh on the 4k+ =P
//edit, to clarify, i copied the “.kodi” -folder from the old Vero to the new via a pc using sftp. Rebooted and voila it seems.
