Hello everyone , Is there a guide to install a unifi controller on a vero4k+
Every tutorial i find is for a pi, and doesnt seem to work.
thanks in advance .
Tom
thanks in advance .
Tom
Explaining what tutorial you are using and exactly where and what problems/errors you run into would be a more useful way to get help.
https://www.hiscorebob.lu/2019/01/installing-unifi-sdn-controller-on-arm-devices-odroid-rpi/
this i used, but none of them won’t install or giving errors through ssh
Maybe there is someone here who uses the controller on the vero and would share the steps to get it on the device.
Maybe this is a solution?
https://hub.docker.com/r/linuxserver/unifi-controller
as last one i find this, which has a complete script but i don’t know if i can use on the vero, this would be the easiest way ![]()
https://community.ui.com/questions/Step-By-Step-Tutorial-Guide-Raspberry-Pi-with-UniFi-Controller-and-Pi-hole-from-scratch-headless/e8a24143-bfb8-4a61-973d-0b55320101dc
