i’m not able to download subtitles anymore using opensubtitles or italiansubs addons, it says that the subtitle has been downloaded but it’s not in the right folder, i found out that it’s being saved in /home/osmc/.kodi/temp and i can’t figure out why. Any help?
Here is the log: http://paste.osmc.io/afodarusaj , interesting part is from line 2500 i guess
Thanks!
Try this:
Go to Settings->Video->Subtitles and change the location where it should download subtitles to “Next to the Video”.
That works with my setup
Hi Sandbird, thank you for the reply.
I already have the option “Next to the video” selected, but it still save the .srt in /home/osmc/.kodi/temp
Did you find a solution for this?
I’m still having this problem…
