after a power failure shutown osmc crashed somehow.
Not recovering by itself.
Tried reinstall
error showing:
After this operation, 0 B of additional disk space will be used.
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LANG = “de_DE.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
dpkg: unrecoverable fatal error, aborting:
files list file for package ‘libjpeg-dev’ is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
Can not solve it
any hints?
Thanks T
