Has anyone noticed on certain files, you get this at the bottom left
Its like only that section is delayed by a fraction of a second? I thought it was only on old files, but also have this on a new episode. It more noticable when the scene changes from light to dark etc. but when you pause it goes away
If no ones seen it before, i`ll reboot, play file and run logs
thanks
Please proceed with providing logs.
Thanks Tom.
reproduce the issue
Can you upload some MediaInfo or a sample of the video affected?
Hi Sam
I can let you download the file off me, I`ve sent you a PM, its 620mb so no idea where else i could upload it
Hi Sam, can you advise what you would like me to do, another file in the same series does the same
I’d suggest proving a sample and some MediaInfo output.
My guess is the resolution isn’t divisible by 8.
See above, if you PM me i can send link to file, but as its on my ftp dont want everyone clicking link
Maybe you could upload an extract to WeTransfer.com or some other file-sharing site?
cheers, long time since i looked at places you could upload to without it been linked to an account
video
recording of the issue
Anyone replicated what im experiencing with that file?
Not yet — I’ll check when I get a chance.
I’ll check this out tomorow
Cheers Sam, did you manage to replicate the problem?
I didn’t see it myself on Tuesday. I’ve asked others to see if they can reproduce the issue. You say it occurs on certain files? Could you post MediaInfo of some other affected files?
Are they all from the same TV series for example?
Does disabling the whitelist and changing Adjust Refresh Rate to Always help?
Before they was all old tv series, so thought it would just phase out. But it does happen on a few different ones, currently its just that tv series
So whitelisted all 1280x720, still same and changed the refresh to always from start/stop, still same
Yeah, whats easiest way to show you the media info, is it the below you need?
thanks
Can you post the full info? Should give you a lot of text which you can copy and paste
this any good?
General
Unique ID : 99181055771870896961703271788495226570 (0x4A9D9396FDD82B6AD002387F5A33C6CA)
Workshop - S02E04 - Episode 4 WEBDL-720p.mkv
Format : Matroska
Format version : Version 4
File size : 557 MiB
Duration : 44 min 5 s
Overall bit rate : 1 768 kb/s
Encoded date : UTC 2022-11-07 06:46:13
Writing application : mkvmerge v51.0.0.18 (‘I Wish’) 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.2
Video
Format : AVC
Format profile : Main@L3.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 1 640 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.071
Stream size : 517 MiB (93%)
Default : Yes
Forced : No
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Bit rate : 125 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 39.5 MiB (7%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 43 min 35 s
Bit rate : 96 b/s
Frame rate : 0.326 FPS
Count of elements : 852
Stream size : 30.8 KiB (0%)
Language : English
Default : No
Forced : No
