Since the Vero4k already has Bluetooth, I wanted to connect my bluetooth speakers with the Vero today. My Vero finds the speakers, but the box can not connect. The same with my mobile device! can someone help me?
any ideas? Any links in the forum? Cheers
Did you install the experimental A2DP package?
If not, I suggest you wait as some work is being done on BT.
thx graham - I was not sure if I had to install it
