hi all!
As the Vero 4K has bluetooth, is there any easy solution to stream audio to a bluetooth headset? If yes, do we have any kind of step-by-step guide how to activate it?
thank you!
hi all!
thank you!
Search for A2DP and you’ll find the experimental Bluetooth audio streaming we’re working on. We hope to have this stable and in the App Store in the near future.
thanks
