Stream audio to OSMC via bluetooth
So, the news for the latest update mentions the added support of bluetooth audio streaming. How does that work?
I’ve followed those instructions to pair my android phone is my vero 4k. This seems to be working ok, both devices see each other connected via bluetooth. But when I play music on my phone there is no sound.
So, is it the proper way to do it? Anything else to configure that I am missing?
Thanks.
Did you find these up-to-date instructions?
It should still have worked but check the advice on uninstalling pulse and the old a2dp app. Also the bit about making sure Kodi isn’t using the default sound device.
I checked everything and I was already fine. But it’s working out actually. Guess I wasn’t patient enough. Sorry for the bother.
