Hello, sorry if this was discussed before, but I couldn’t find it in the forum.
I would like to stream the content from the Vero 4K to Android tablet or PC. I manage to make it visible in the network, but when I’m trying to access the files, nothing is shown.
Please guide me, in a newbie way, how to do it.
Yes, but I’m convinced that is a problem with the settings I made
It didn’t asked for any credential and for sure here can be the issue. Also if I remembered correctly I didn’t set-up credential to Samba either.
I will try with Yatse in few hours, but would be nice if you can help me setting Samba to have all the correct info
I checked and there is no option in the settings. So everything is default
In ES FE, OSMC is visible but when I’m trying to connect by LAN nothing happen, simply doesn’t open anything. Another option is to connect FTP and is asking for user name and password… which I have no idea from where to setup.
I tried using Yatze on Android, but from what i found is only a remote control. I see all the content from the OSMC, but once I’m trying to play anything is sending the command to the OSMC instead of playing on Android
