Streaming from Osmc to ipad
Hi there,
I use the android app Yatse to stream from OSMC to my tablet or phone.
Does anyone know if there is a similar app to allow streaming to an iPad or iPhone ?
You can enable the dlna server in osmc and then try some dlna apps on the ipad to stream your library from osmc.
Thanks, I don’t think I had DLNA turned on.
There’s an app called Buzz player on the iPad that I would play the stream.
Thanks for your help.
I can recommend Infuse
