Stripping OSMC
Hi guys,
I think I’m finishing my OSMC configuration and now, before make an SD image, I’d like to strip the OSMC distribution from all the package I don’t use for external connect:
I let connection to my Raspy via ssh/sftp, openvpn and I’ve just removed samba to install NFS… is there any other “connectin” package to remove to be sure I have the control of all the way to connect to my Raspy?
Is there a list of the optional packages that may I consider to remove in order to strip the OSMC distribution? I just use my Raspy as Mediacenter…
Thanks!
OSMC is sufficiently stripped for use as a media center. You don’t need to do anything and removing packages could cause problems.
Okay, thanks for the confirmation! :slight_smile:
