Hello Everyone,
I have created a .strm file with a single udp url in it. I created the file through putty. However when I try to open the file in OSMC, the file is not visible. Am I doing anything wrong here?
Hello Everyone,
Where have you created the file and how are you trying to access it from Kodi?
I have created under Home\Movies folder and I am trying to open it through videos
Then you would need to add that path (not the file) to your library or go via “files”
I tried that. I am trying to access the path via file and when I browse the location, I can only see the folder which I have created, but not the strm files.
Than add the folder to the library!
Awesome. It worked.
