I have an IQaudio DigiAMP+ hat on my Raspberry Pi 3, and the setup worked fine before the upgrade. If I activate the hat in /boot/config-user.txt with dtoverlay=iqaudio-dacplus,unmute_amp
I have no sound, playback crash and when goin into the “system” menu in settings the ui is stuck and I can only reboot or restart mediacenter service.
Anybody else with similar issues?
I have even tried to completely remove .kodi folder after activating the hat, but it still behaves the same. I have installed pulseaudio, and I will try to revert this and see if it changes anything
alright uninstalling pulseaudio, helped. But I would really like to have the option to use pulseaudio for the IQaudio hat, so more than one sound source can play at the same time.
Is there another way than pulseaudio to do this?
EDIT:
OK, pulseaudio without hat activated worked fine in kodi, so tried to cut loading of pulseaudio a bit closer, and setting only load-module module-alsa-sink device=hw:1,0
and removing the load-module module-udev-detect
part from /etc/pulse/default.pa seemed to make kodi stay happy
Hi!
I have the same problem: RPi 3b + IQaudio DAC Pro hat.
After the update to version 2021.08-1 no sound from the DAC.
Selecting ‘iqaudio-dacplus’ from MyOSMC the “System” menu hangs on “audio” settings, with no possibility to choose the DAC for audio output.
Ok, I manually edited config-user.txt changing from ‘iqaudio-dacplus-overlay’ to ‘iqaudio-dacplus’ (removing ‘-overlay’) and seems to work.
Thanks fzinken
Just to spread the word, this manual edit (changing from ‘iqaudio-dacplus-overlay’ to ‘iqaudio-dacplus’ (removing ‘-overlay’) ) is required to get an IQaudio digiAMP+ working with a raspberry pi 4.
