Hi all,
My Vero 4k gets stuck on “buffering” for any video I play, irrelevant of source (external drive, stream or a drive connected to my router), quality or length. To fix it I need to restart the device. After one or two items have played, the problem would reoccur.
I only got it a few months ago and the problems started about 2 months ago.
I have installed the latest updates available. Do you have any advice on how to find and fix the issue?
So, in summary:
- activate the logging
- reboot the OSMC device
- reproduce the issue
- upload the log set either using the
Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
- publish the provided URL from the log set upload, here
Tom.
How invested are you in your current setup?
Easiest fix is to probably reinstall OSMC. See Reinstalling OSMC - Vero 4K - OSMC.
