Hi guys, I hope someone will be able to help me with this issue that I am trying to fix for 2 days now.
I have a raspberry pi 3 with Kodi 17.3 and I have installed Libreelec and OSMC. The issue is occuring on both os it doesnt matter if it’s Libreelec or OSMC.
So everytime I try to add my movies to my library, it get stuck on the Preparing and Scanning for new content, I let it run for about 1h last night and 1h today, it never progress pass 0% or on osmc the progress bar does not move at all.
If I click on a button on my controller while the scanning is running, the rpi3 crash and I need to unplug the power.
Im trying to add it by NFS, I have one folder that contains around 700 movies files.
kodi.log: http://paste.osmc.io/uhimurigap.vhdl
kodi.old.log: http://paste.osmc.io/veruvasaku.vhdl
If you need more information please let me know.
Thanks.
Can you give us grab-logs -A
I don’t know what this log is…
I did a complete logs upload from My OSMC, but it’s older, not at the same time as my kodi.log in my first post.
I did not upload the log while the issue occured since it crash when I click on my controller. If the log you want is included in the complete my osmc upload and it’s only information about config and hardware and you still want it, I will give it.
Let me know.
Yep, I’d like to see that do I can specifically see your sources.
First, i’d remove the upnp source you already have. Second, use MyOSMC and check for and install updates. Third, does your source have Movies and TV Series separated?
First: I deleted the upnp source 2min after I created this topic, nothing changed.
Second: I will check for updates but I don’t think it’s related since I have the same problem with Libreelec and other skins.
Third: I have a 4TB WD My Cloud Drive with a Static IP called Multimedia, at the root of the drive I have one folder for Movies and another one for TV Series.
In media source, If I try to browse and add directly the movies folder it get stuck in a loading loop and crash if I click on something on my controller. (That’s even before I am able to click on Set content to put it in videos and Scan for content, just trying to add this folder directly in my files network is an issue). I could not even get the scan started.
So what I did is I added the drive Multimedia, put it in videos. And when I go to video I browse to my movies folder and slick on Set content and then I am able to start the scan but I does not progress and crash if I click on something.
It seem to be a problem with this specific folder because I am able to scan my TV Series without issues, I also have another folder with only like 5 movies and I can scan it without problem.
My first guess was that there is too much files to process or something, but I really don’t know.
Thank you for your help.
