When I start my Vero 4K I get the notice that I only got 31MB left. How do I free the disk?
When I try to connect via network, I’m supposed to enter some username and pass that I’m totally unaware of. When I use the usb, it does’nt show at all. That I can understand, if it’s ony for connecting things to the Vero, and not the other way around. But the network?
Is there any other way to fix this, that I don’t see?
Henrik
try the defaults osmc and osmc
are you then OK with a linux commandline?
Osmc works fine. Thanks for helping.
I’ll give it a shot on the commandline, with som guidance.
PuTTY is now downloaded and running. Login successful. Now, it’s just to find the directory that nedds cleaning.
A handy tool for looking for disc usage is ncdu. To install it:
sudo apt install ncdu
and to run it:
sudo ncdu /
It may take a while to scan, but will give you a good summary of where the space is being used.
