Hi, what is the preferred way to copy files from a Windows PC to the PI2 running OSMC RC with attached USB disks (which are formatted as NTFS):
- Using the SAMBA server or
- Using the vsftp server?
Thanks…Dick
Thanks…Dick
It would seem samba would be the easiest solution.
Just to add – Samba is available via the App Store.
I added SAMBA via the App Store but there could be a viable Linux reason (note that I’m a Linux noob) that FTP would be a better choice…
My preferred method is to use WinSCP. This connects via SSH so no additional services required.
