So far anything that I’ve played has played without any problems on my Vero 4K, many UHD HDR Blurays without any stutters.
Yesterday I watched “Stranger Things - S03E06 - [2160p WEB h265][DEFLATE].mkv” and at 35:58 there is a slow zoom out of static on an old CRT, probably the bitrate here is really high and the Vero 4K stuttered and could not keep up.
Wondered if anybody else had something similar and if I should start tweaking the cache?
Vero is connected with a 1 Gbit network to a Windows 2019 Fileserver that hosts the files.
General
Unique ID : 283059423293875018354343490577590092092 (0xD4F3430E414E49CAA786552BF77B813C)
Complete name : Stranger Things - S03E06 - [2160p WEB h265][DEFLATE].mkv
Format : Matroska
Format version : Version 4
File size : 6.60 GiB
Duration : 59 min 38 s
Overall bit rate : 15.8 Mb/s
Encoded date : UTC 2019-08-21 09:33:01
Writing application : mkvmerge v19.0.0 ('Brave Captain') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Video
Format : HEVC
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 15.2 Mb/s
Width : 3 840 pixels
Height : 1 920 pixels
Original height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.086
Stream size : 6.33 GiB (96%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : E-AC-3
Format/Info : Enhanced AC-3
Commercial name : Dolby Digital Plus
Codec ID : A_EAC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Compression mode : Lossy
Stream size : 273 MiB (4%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 36 min 47 s
Bit rate : 1 b/s
Count of elements : 16
Stream size : 439 Bytes (0%)
Title : English (Forced)
Language : English
Default : Yes
Forced : Yes
Text #2
Format : UTF-8
Duration : 54 min 46 s
Bit rate : 58 b/s
Count of elements : 836
Stream size : 23.4 KiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Duration : 57 min 58 s
Bit rate : 73 b/s
Count of elements : 1133
Stream size : 31.1 KiB (0%)
Title : English (SDH)
Language : English
Default : No
Forced : No
