I seem to have problems with 1080p videos on my Vero since the upgrade to Kodi 17. I didn’t notice at first because I have a mix of 720p and 1080p videos in my library and when I stumpled upon a stuttering video I just thought it was a bad encode. However I have had more and more problems and now found out that the stuttering only occurs with 1080p videos and that there is (as good as) no stutter with OSMC 2017-01.
The stuttering in detail seems like the video is moving normally but every 2 - 4 seconds it seems to lag a bit behind, speed up to make up for it, go normal, lag behind, speed up, etc. This is especially visible in scenes where the camera pans vertically or horizontally.
Adjusting the display refresh rate is active (see detailed settings per image, furhter down)
So I prepared two SD cards - one with a fresh 2017-03 and one with a fresh 2017-01. Below you will find the log files for both and the media info of the played file. Hopefully you can figure out, what the problem is!
I am going to configure the 2017-01 system already to my “daily use” (adding add-ons, installing additional applications) to not squander with the WAF
but I should be able to switch through the two versions, should you need additional info. I will also keep the 2017-03 otherwise untouched if you have some suggestions/improvements to test there.
General setup
Vero is attached via LAN to a router. There is a 5Ghz Wifi Bridge to another router, where the NAS is attached. Speedtests with the ‘dd’ command resulted in ~30 MB/s, so that’s definitely not the bottleneck. I also tried ~2GB files on a USB stick - the results are the same.
The files of the NAS are accessed via NFS share which is mounted to a local folder at boot via /etc/fstab
Media info
General
Unique ID : 207781908916030101946095277698649394047 (0x9C51570C18C72EABA152459549AB8B7F)
Complete name : The Girl on the Train.2016.1080p.DON.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 16.1 GiB
Duration : 1h 52mn
Overall bit rate : 20.6 Mbps
Movie name : The Girl on the Train 2016 1080p BluRay DTS x264-DON
Encoded date : UTC 2017-01-09 10:21:33
Writing application : mkvmerge v8.2.0 ('World of Adventure') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Attachements : Cover.jpg
DURATION : 01:51:06.910000000
NUMBER_OF_FRAMES : 1169
NUMBER_OF_BYTES : 34385
_STATISTICS_WRITING_APP : mkvmerge v8.2.0 ('World of Adventure') 64bit
_STATISTICS_WRITING_DATE_UTC : 2017-01-09 10:21:33
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Video
Format : AVC
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 52mn
Bit rate : 18.5 Mbps
Width : 1 920 pixels
Height : 1 038 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.386
Stream size : 14.4 GiB (90%)
Title : The Girl on the Train 2016 ~ HDBits Internal
Writing library : x264 core 148 r2705+54 9f484c1 t_mod_Custom [8-bit@all X86_64]
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.05:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=17.7000 / qcomp=0.65 / qpmin=0:0:0 / qpmax=69:69:69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.30 / pb_ratio=1.20 / aq=3:0.75 / aq-sensitivity=10.00 / aq-factor=1.00:1.00:1.00 / aq2=0 / aq3=0 / zones=26,399,crf=14.7/411,1055,crf=14/9523,9720,crf=17/20572,20643,crf=17/21038,21280,crf=17/21518,21812,crf=17/45990,46141,crf=17/79399,79514,crf=14/82952,83126,crf=14.7/85826,86116,crf=14/86117,86407,crf=17/89642,89925,crf=16/93652,93834,crf=16/95324,95647,crf=17/96037,96149,crf=14/117843,117925,crf=16/118062,118206,crf=14/121279,121659,crf=14/121751,122355,crf=14.7/123544,124426,crf=16.5/142397,142429,crf=14.7/142531,142568,crf=14.7/150016,150024,crf=14/153085,153093,crf=14/153100,161238,crf=22
Language : English
Default : Yes
Forced : No
Matrix coefficients : BT.709
DURATION : 01:52:05.010000000
NUMBER_OF_FRAMES : 161239
NUMBER_OF_BYTES : 15855806383
Audio #1
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Duration : 1h 52mn
Bit rate mode : Constant
Bit rate : 1 509 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 1.18 GiB (7%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 52mn
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Bit depth : 16 bits
Stream size : 154 MiB (1%)
Title : Commentary with director Tate Taylor
Language : English
Default : No
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Title : SDH
Language : English
Default : No
Forced : No
Text #3
Format : UTF-8
Language : English
Default : No
Forced : No
Text #4
Format : UTF-8
Language : French
Default : No
Forced : No
Text #5
Format : UTF-8
Language : Spanish
Default : No
Forced : No
Text #6
Format : UTF-8
Language : Vietnamese
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:06:01.778 : en:00:06:01.778
00:09:29.903 : en:00:09:29.903
00:18:15.970 : en:00:18:15.970
00:25:26.150 : en:00:25:26.150
00:32:04.506 : en:00:32:04.506
00:37:04.973 : en:00:37:04.973
00:44:52.315 : en:00:44:52.315
00:49:22.459 : en:00:49:22.459
00:55:07.012 : en:00:55:07.012
00:59:36.031 : en:00:59:36.031
01:03:34.811 : en:01:03:34.811
01:09:25.787 : en:01:09:25.787
01:14:36.430 : en:01:14:36.430
01:19:08.702 : en:01:19:08.702
01:23:44.728 : en:01:23:44.728
01:28:07.491 : en:01:28:07.491
01:33:49.457 : en:01:33:49.457
01:38:54.554 : en:01:38:54.554
01:45:55.182 : en:01:45:55.182
2017-03
http://paste.osmc.io/nazekibate
Resolution: 1920x1080p
Refresh rate: 60
Audio passthrough: On for all formats
Adjust display refresh rate: On start/stop
Sync playback to display: Off
2017-01
http://paste.osmc.io/hehuzurike
Refresh rate: 60
Vertical blank sync: Let driver choose
