A post was merged into an existing topic: Pi3 stuttering with August update
Hi mangoat1,
There is a proper fix on the way, in the mean time I suggest trying this:
Thanks Tom.
Hopefully the issue is now addressed
- Login via the command line
- Edit the file
/etc/apt/sources.list - Add the following line:
deb http://apt.osmc.tv stretch-devel main - Run the following commands to update:
sudo apt-get update && sudo apt-get dist-upgrade && reboot - Your system should have have received the update.
First, @sam_nazarko, thank you SO much for RaspBMC and all the work you have done since a long long time back. Been a lurking fan since my first Pi B. Second, I tried the above with a Pi Zero and it did not solve the issue.
Sorry to be the bearer of bad news.
Logs Here: https://paste.osmc.tv/ekehetixas.vhdl
cat /proc/cpuinfo shows:
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 847.52
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7Hardware : BCM2835
Revision : 900093
Serial : 0000000017c26e34
This is the first report of someone with a Pi Zero reporting the issue. The fix was for Pi 1/2, so it would be good to post logs.
@Tom_Doyle thanks, once i figured out how to use ssh, i did as you said and its rectified the situation.
cheers.
goat
Added logs to original message. Let me know if you want me to do another “upgrade” back down to the original version to run it.
Instead of :
How do I get a list of valid packages that match this? I didn’t see anything for Pi Zero searching for
apt-cache search rb
nor
apt-cache search zero
Just confirming that the development update (4.14.34-6-osmc) appears to be working without issue on a Raspberry Pi B+.
Thanks for the quick turnaround on this Sam.
Answering my own dumb question, the Pi Zero uses the same image as the Pi 1, therefore
sudo apt install --reinstall rbp1-image-4.14.34-4
Works fine and in fact fixed my issue also.
Note: I think I ran 4.14.34-5 not 4.14.34-6 in my test on the Zero. 4.14.34-6 Was not available at the time.
Yes, seems to solve the problem on my Pi B rev 2.
Thanks @sam_nazarko
4.14.34-6 Confirmed working on RPi Zero.
Raspberry Pi Model B Rev 2 works well with the 4.14.34-6.
Thanks @sam_nazarko
I’ve pushed these fixes as an update now. Thanks for testing.
