Hi, Just a heads up of possible playback issue…
Only just took the June update on Vero 2. After the update, I saw some stuttering on MKV videos especially during high rate of change / motion in picture - or with high bitrate sources like MKVs of Blu-ray Discs. With some corruption on sound at those times.
Rebooting an extra time seems to have cured it - just done more testing - But not 100% sure yet but looks promising.
Anyone else had issues ?
BTW the reboot took 3 minutes (“Wait for complete device initialisation”) which seemed odd.
We would need to see some logs to get a better understanding of what’s going on here
Thanks Sam. I’ll keep an eye on it and update this thread. Can’t really see why an extra reboot would have fixed it
I notice some stuttering and buffering too for some 4K movies on my Vero 4K+ connected with LAN cable. Files are on a Linux server with RAID10 disk config. Throughput tested with dd shows XXXX MB/s (the command is running now…will update).
File video details:
Video
Format : HEVC
Commercial name : HDR10
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 40 min
Bit rate : 69.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.347
Stream size : 48.4 GiB (94%)
Writing library : ATEME Titan File 3.9.4 (4.9.4.0)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 766 cd/m2
Maximum Frame-Average Light Level : 466 cd/m2
The behavior is random so it seems and starts with stuttering followed by a short freeze and than the buffering ‘circle’ is shown for 5 to 20 seconds.
More background: TV is 4K LG OLED and the Force 4:2:2 colour subsampling is enabled as well as Adjust display refresh rate = On start/stop.
I’ll collect logfile from such an event and will add it here, meanwhile the logfile without debugging enabled:
2020-08-09 10:32:13.452 T:4067123200 NOTICE: VideoPlayer::OpenFile: smb://gandalf/movies/My.Movie/My.Movie-2160p-UHD-HDR-DTS-HD-AC3-NL-RetailSub-REMUX.mkv
2020-08-09 10:32:13.454 T:3964842720 NOTICE: Creating InputStream
2020-08-09 10:32:13.515 T:3964842720 NOTICE: Creating Demuxer
2020-08-09 10:32:14.029 T:3964842720 NOTICE: Opening stream: 0 source: 256
2020-08-09 10:32:14.029 T:3964842720 NOTICE: Whitelist search for: width: 3840, height: 2160, fps: 24.000, 3D: false
2020-08-09 10:32:14.030 T:3964842720 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.00 - Full Screen (33) (weight: 0.000)
2020-08-09 10:32:14.113 T:4067123200 NOTICE: VideoPlayer: OnLostDisplay received
2020-08-09 10:32:14.113 T:4067123200 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2020-08-09 10:32:14.114 T:4067123200 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
2020-08-09 10:32:14.334 T:4067123200 ERROR: GetString: error reading /sys/firmware/devicetree/base/buggymali
2020-08-09 10:32:14.673 T:3964842720 NOTICE: CVideoPlayerVideo::OpenStream - Creating codec: 173
2020-08-09 10:32:14.678 T:3964842720 NOTICE: Creating video thread
2020-08-09 10:32:14.678 T:3601294048 NOTICE: running thread: video_thread
2020-08-09 10:32:14.679 T:3964842720 NOTICE: Opening stream: 1 source: 256
2020-08-09 10:32:14.679 T:3964842720 NOTICE: Finding audio codec for: 86020
2020-08-09 10:32:14.679 T:3964842720 NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder dca
2020-08-09 10:32:14.679 T:3964842720 NOTICE: Creating audio thread
2020-08-09 10:32:14.679 T:3317420768 NOTICE: running thread: CVideoPlayerAudio::Process()
2020-08-09 10:32:14.680 T:3964842720 NOTICE: Opening stream: 3 source: 256
2020-08-09 10:32:14.726 T:4067123200 NOTICE: VideoPlayer: OnResetDisplay received
2020-08-09 10:32:14.738 T:3317420768 NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, no pass-through)
2020-08-09 10:32:15.268 T:4067123200 NOTICE: Whitelist search for: width: 3840, height: 2160, fps: 24.000, 3D: false
2020-08-09 10:32:15.269 T:4067123200 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.00 - Full Screen (33) (weight: 0.000)
2020-08-09 10:32:34.966 T:3317420768 NOTICE: CVideoPlayerAudio::Process - stream stalled pts:2418.549 clock:2418.558
2020-08-09 10:32:37.835 T:3601294048 ERROR: CAMLCodec::AddData: packet to big: 460390, probably corrupted
2020-08-09 10:32:38.309 T:3601294048 ERROR: Previous line repeats 239 times.
2020-08-09 10:32:38.309 T:3601294048 ERROR: CAMLCodec::AddData: packet to big: 369525, probably corrupted
2020-08-09 10:34:40.012 T:4067123200 ERROR: Previous line repeats 14407 times.
2020-08-09 10:34:40.013 T:4067123200 NOTICE: VideoPlayer: OnLostDisplay received
2020-08-09 10:34:40.241 T:4067123200 ERROR: GetString: error reading /sys/firmware/devicetree/base/buggymali
2020-08-09 10:34:40.544 T:4067123200 NOTICE: VideoPlayer: OnResetDisplay received
2020-08-09 10:34:40.545 T:4067123200 NOTICE: Whitelist search for: width: 3840, height: 2160, fps: 24.000, 3D: false
2020-08-09 10:34:40.546 T:4067123200 NOTICE: Display resolution ADJUST : 3840x2160 @ 24.00 - Full Screen (33) (weight: -0.000)
2020-08-09 10:34:40.774 T:4067123200 NOTICE: VideoPlayer: OnLostDisplay received
2020-08-09 10:34:40.984 T:4067123200 ERROR: GetString: error reading /sys/firmware/devicetree/base/buggymali
2020-08-09 10:34:41.292 T:4067123200 NOTICE: VideoPlayer: OnResetDisplay received
2020-08-09 10:35:12.367 T:3317420768 NOTICE: CVideoPlayerAudio::Process - stream stalled pts:2866.133 clock:2866.138
2020-08-09 10:35:14.883 T:3601294048 ERROR: CAMLCodec::AddData: packet to big: 322805, probably corrupted
2020-08-09 10:35:57.403 T:4067123200 ERROR: Previous line repeats 15910 times.
2020-08-09 10:35:57.403 T:4067123200 NOTICE: CVideoPlayer::CloseFile()
2020-08-09 10:35:57.404 T:4067123200 NOTICE: VideoPlayer: waiting for threads to exit
2020-08-09 10:35:57.409 T:3964842720 NOTICE: CVideoPlayer::OnExit()
2020-08-09 10:35:57.410 T:3964842720 NOTICE: Closing stream player 1
2020-08-09 10:35:57.410 T:3964842720 NOTICE: Waiting for audio thread to exit
2020-08-09 10:35:57.441 T:3317420768 NOTICE: thread end: CVideoPlayerAudio::OnExit()
2020-08-09 10:35:57.441 T:3964842720 NOTICE: Closing audio device
2020-08-09 10:35:57.486 T:3964842720 NOTICE: Deleting audio codec
2020-08-09 10:35:57.487 T:3964842720 NOTICE: Closing stream player 2
2020-08-09 10:35:57.487 T:3964842720 NOTICE: waiting for video thread to exit
2020-08-09 10:35:57.505 T:3601294048 NOTICE: thread end: video_thread
2020-08-09 10:35:57.507 T:3964842720 NOTICE: deleting video codec
2020-08-09 10:35:57.551 T:3964842720 NOTICE: Closing stream player 3
2020-08-09 10:35:57.780 T:4067123200 NOTICE: VideoPlayer: finished waiting
2020-08-09 10:35:57.780 T:4067123200 NOTICE: CVideoPlayer::CloseFile()
2020-08-09 10:35:57.780 T:4067123200 NOTICE: VideoPlayer: waiting for threads to exit
2020-08-09 10:35:58.041 T:4067123200 ERROR: GetString: error reading /sys/firmware/devicetree/base/buggymali
2020-08-09 10:37:51.634 T:4067123200 NOTICE: Samba is idle. Closing the remaining connections
Vero 2 and Vero 4K/4K+ are different hardware and have different versions of Kodi, so your issue is unlikely to be related.
Your log file doesn’t show anything relevant.
