Another thing I noticed is that you have “Update Library On Start” enabled. I doubt that’s a problem, but try turning that off.
About debug logs:
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
OK - so i repeated everything and tried playing goonies, then uploaded the log: https://paste.osmc.tv/oduloyajab
Interesting, with the debug running I could see that the FPS was flicking between 23.4fps and 24.4fps constantly. Does that help you guys at all?
Found it - changed it - that’s fixed it!!! NICE SPOT!!
Thank you all for the help!
so the issue was hardware acceleration - I have no idea why or how I had turned it off.
I had a feeling it would be a checked or unchecked box that I had accidentally turned on or off.
Great system for help here - really appreciate all the support.
Thanks again.
As a support guy myself, it’s been a pleasure catching up to this thread!
Reading it as if NASA tried to rescue a lost Astronaut…man, the dedication…great work guys! Love this community.
