Symptoms:
- Issues started around two weeks ago (give or take)
- Picture pausing whilst sound continues, pauses in the order of a second, happens in bursts.
- Can go for a few minutes after re-boot without problems, but then they happen continuously.
- Bottom-half of the screen displays random blocks and colours in about 1/10th of the glitches.
- Impossible to watch anything
- I get the white frowny face on the blue background quite often - saw it multiple times today during scanning and log generating for example. Happened during updates too.
Setup:
- Sources are external NAS mounted (via /etc/fstab) via NFS
- HDMI switching via Yamaha receiver
What I’ve done:
- Swapped HDMI cable and Ethernet cable
- Rebooted many, many times
- Played same files via Infuse on Apple TV (from same NAS sources) - all good
- Re-installed OSMC via qt_host_installer twice - one with 2024.04-1, then again with 2024.02-1
- Restored from backup for first re-install, then vanilla with second install (e.g. install, then play files)
- Swapped the Vero V for my old (and trusty) Vero 4K+ - all good
- Turned all logging on, rebooted twice, played with glitches, then submitted logs via OSMC itself
I fear that the hardware has gone bad somewhere. When it glitches I sometimes see this, but not always:
osmc CPtsTracker: detected pattern of length 1: 41708.33, frameduration: 41708.333333
Feels like a hardware issue to me ![]()
Cheers,
Paul.
