Hello everyone,
i found a lot of topics regarding to stuttering issues with the vero4k and 4k+ but i was not shure if any of this topics already would help in my specific problem.
I have a vero4k with latest stable release of OSMC. TVheadend is running on a different raspi with DVB-T2 (german edition). Recordings are save to a 3rd NAS storage. TVheadend is integrated to OSMC via the Addon.
Via tvheadend i have some recordings to watch shows later. Playing back this records later from the beginnen is not a problem. Everything is fine. But if i skip through the recorded timeline forward or backward i get really bad video stuttering while sound is fine all the time. I made a video snapshot of it: Dropbox - File Deleted
Maybe someone of you would like to reproduce. You can test this with my recording: Dropbox - File Deleted - Simplify your life
Best regards,
Bond
Does this only happen with HEVC? I think Germany switched to it for live broadcasts recently
I can’t compare with H.264 recordings. I’m using tvheadend only with DVB-T2 and HEVC.
But playback of x265 content from mkv files without the combination with tvheadend normaly is not a problem.
Ok — can you try change recordings to MKV and see if the issue still occurs?
Good idea.
Unhappily this didn’t helped.
Ok, if you copy a MKV to local storage like USB does it help?
Can you post a debug log?
Hello Sam,
sorry for the delay.
Today i made some new recordings with mkv and tested some different locations to play back the file.
There is no difference between playing the recorded mkv file via TV-Plugin, from a samba share or completly from the local storage.
debug kodi.log - Dropbox - File Deleted
test-file: Dropbox - File Deleted
Best regards,
Bond
Please upload the logs via My OSMC
Any news regarding to this?
I don’t have a solution for this yet but it is still on the list. I have some ideas and would like to resolve this promptly.
Hello Sam,
what is the status with that?
The problem still exists with the latest release. I think after the november update is was worse with .ts-files. After switching to mkv it is better but the stuttering problem after skipping is still there.
2nd problem with mkv, my osmc always starts activates the vtx based subtitles…
Curiously, i have this only with ARD-programs, not with ZDF-programs.
Do you need a new record for testing?
Best regards
Bond
This should have now been fixed for some time.
I’d suggest trying the staging repository.
To test this update:
- Login via the command line
- Edit the file
/etc/apt/sources.list
- Add the following line:
- Run the following commands to update:
- Your system should have have received the update.
I also recommend you edit /etc/apt/sources.list
again and remove the line that you added after updating. This will return you to the normal update channel.
Thanks for your fast replay.
I made this update yesterday and tested with a recording made at the same day.
The stuttering is still there at least with mkv packaged recordings and hevc.
If .ts files can be played back again i can’t say.
Bond
Thanks for confirming. In this case it would be good to get another recording
Hey,
It seems that the problem finally is fixed now with the new major release.
I think the the video stack does a good job ![:wink: :wink:](https://discourse.osmc.tv/images/emoji/twitter/wink.png?v=10)
![:+1: :+1:](https://discourse.osmc.tv/images/emoji/twitter/+1.png?v=10)
So this topic can be closed.
Thanks for the work!
