I have suttering/lag issues when playing videos on my Vero 4k+. I have noticed this usually only happens with anime .mkv files that are high quality (4gb+ for 25min episode), but I could be wrong. The files play fine on my Windows/Ubuntu machine by using VLC, but stutter and make my Vero 4k+ unresponsive and even crash sometimes (can’t reproduce though, very rarely happens).
I’ve enabled debug logging and rebooted the device twice, then started playing my sample video file for 2 minutes, then grabbed these logs:
http://paste.osmc.tv/gitedayihu
Here’s the media info of the file:
~ mediainfo Neon.Genesis.Evangelion.S01E01.Angel.Attack.HDTV-720p.mkv
General
Unique ID : 225345005003599238889228022966197304211 (0xA987DE8A25924E0698AA415AEED63B93)
Complete name : Neon.Genesis.Evangelion.S01E01.Angel.Attack.HDTV-720p.mkv
Format : Matroska
Format version : Version 4
File size : 3.28 GiB
Duration : 23 min 21 s
Overall bit rate : 20.1 Mb/s
Encoded date : UTC 2018-01-13 01:07:48
Writing application : mkvmerge v18.0.0 ('Apricity') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Attachments : 26746_0.ttf / FRADM_0.TTF / GLECB_0.TTF / JESFE_0.ttf / Marker SD_0.ttf
Video
Format : AVC
Format profile : High 10@L4.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 18.3 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.491
Stream size : 2.99 GiB (91%)
Writing library : x264 core 129 r2245+729M 1a52e03
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=11 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.10 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / fgo=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=0 / crf=17.0 / qcomp=0.70 / qpmin=0 / qpmax=81 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / pb_ratio=1.30 / aq=3:0.70
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : FLAC
Format/Info : Free Lossless Audio Codec
Codec ID : A_FLAC
Bit rate mode : Variable
Bit rate : 1 816 kb/s
Channel(s) : 6 channels
Sampling rate : 48.0 kHz
Frame rate : 11.719 FPS (4096 SPF)
Bit depth : 16 bits
Compression mode : Lossless
Stream size : 304 MiB (9%)
Writing library : libFLAC 1.2.1 (UTC 2007-09-17)
Language : Japanese
Default : Yes
Forced : No
MD5 of the unencoded content : BE172F9D848235D1B1C06F479F7A707E
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 23 min 20 s
Bit rate : 121 b/s
Frame rate : 0.246 FPS
Count of elements : 344
Stream size : 20.7 KiB (0%)
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : ja:Opening
00:01:30.424 : ja:A-part
00:10:59.367 : ja:Eyecatch
00:11:03.621 : ja:B-part
00:22:00.486 : ja:Ending
00:23:05.926 : ja:Preview
I’ve cut a one minute sample from the original video if that helps, here’s the link: https://we.tl/t-WGDMvac2y2
I can also provide the full video (dm me).
