Remux to MKV using something like MakeMkv and you should be fine
Hi thanks for your reply
But i donāt have want to remux all my iso 4k bluray iāll be to long
Julien
Than I donāt know, maybe @sam_nazarko or some other support staff can help you
If you already have them ripped to ISO, remuxing to mkv should not take long. Plus you can save space by removing the extras and un-used sountracks/subs.
Also, BD ISO is not currently handled well by Kodi. Supposedly this will improve with V18.
Sorry, itās not exactly bluray iso, itās an extract of the files with all the directory
Julien
Are there any specific titles causing this problem or does it happen with all of them?
Hi Sam,
Itās happening with all my 4k blu-ray depending on frames rates.
When I test this files on USB disk attached on vero4k itās working perfectly
Julien
How are your shares mounted?
On the Vero 4K (non +), you may benefit from using OS mounts for better performance.
Iām using nfs sharing and Iām adding it in library as a video source
Julien
I think using an fstab based mount will solve this for you
Hi Sam,
I tested using fstab, itās working perfectly.
Thanks a lot
julien
