I did a quick search in the forums but didn’t as a definitive answer to this problem. Any of my VC-1 videos stutter and play in slow motion. This problem exists in the latest builds of Libreelec and OSMC on my Pi 3. I have zero issues with my Chromebox running Libreelec. Is there definitive solution to this under than muxing the files to H.264?
Did you buy the VC-1 key? That fixed the problem for me.
Holy crap i didn’t know there was such a thing. I will give that a try. Thank you.
So I ordered my codec keys and I’ve attempted to input them via PiConfig as well as manually. When I reboot it still shows the codec being disabled. Here is my config.txt file copy and pasted
GNU nano 2.7.4 File: /boot/config.txt
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
decode_MPG2=0xdfaa4d20
decode_WVC1=0x534b39c
Looks like the WVC1 is missing a digit
If it is, it’s not on my end. I just confirmed it with the codes in the email.
