Is it possible to extend the width of the column showing the file name of the subtitle when downloading subtitles? Often the type of subtitle is at the end of the filename, eg. “HI”. There should be enough room for an extension.
Steinar
Steinar
Which subtitle addon are you using, there are quite a few; if you try another subtitle addon do you get the same issue?
Which skin are using? have you tried another skin? We need to find out if the issue is related to the skin or if its an addon issue.
Thanks Tom.
I am using the default OSMC-skin, have not tried other skins.
It’s the same problem with all subtitle addons. I currently use BSPlayer.
Could you please try it the kodi Estuary skin, just need to confirm its a skin issue; rather than a kodi issue.
Thanks Tom.
I will try later today.
Steinar
Estuary shows complete filename.
Steinar
Ok seems to be an issue with the OSMC skin, will flag to the skin developers.
Thanks Tom.
@grahamh any thoughts on this?
Thanks Tom.
I’ll have a look, but I’m no expert.
Keep your eyes peeled for the next OSMC update…
The feature should be present in yesterday’s April update. The topic will be closed tomorrow, if there’s nothing to add, and I’ll mark the feature request solved.
This topic was automatically closed after 24 hours. New replies are no longer allowed.
