Subtitle will not be saved
help with subtitles.
logs are here
https://paste.osmc.tv/irifalicax
problem is I use subscene to download subtitles which works fine, the problem is I have to download the subtitle every time I stop the movie.
I selected the option to store subtitles localy in osmc but that doesnt seem to help. I do see the file in the osmc selected folder but it kodi doesnt see to recognize that this is for the movie.
it is stored as “file.subtitlelanguange.sr”
am I the only experiencing this problem?
If the subtitle is being stored change subtitles location to your osmc selected folder, instead of next to video. Or select the subtitle folder during playback via the OSD.
Thanks Tom.
Conflounce skin doesnt have the option to save the subtitle at download
During playback if you bring up Audio settings (looks like speaker) Can you not set subtitle options there?
Thanks Tom.
There is an option to browse and select a subtitle file, but no option to save as and select a file
Do you have same issue on the osmc or estuary skin?
Thanks Tom.
