I can post logs if it may help sorting this out. What log level?
Is it ok that the logs are from Kodi 20.2 on Fedora instead of Kodi 20.2 from OSMC? As far as I can see they both have the same problem.
Searching the forum ("@darwindesign subtitles") did not really help me. Many results are from older versions of Kodi.
Subtitle detection is not the problem. When I play video “Foo.mpg” and there is a file “Foo.srt” next to it, this is detected as “Unknown - (External)”. When named “Foo.nl.srt” it is detected as “Dutch - (External)”. It is just not shown (subtitle disabled).
Similar for MKV (I think this is the relevant part of the log):
2023-12-12 13:52:46.787 T:2150886 debug <general>: ------ Window Init (Pointer.xml) ------
2023-12-12 13:52:46.788 T:2150886 debug <general>: CVideoGUIInfo::InitCurrentItem(/volume1/Storage0/Video/Series/A_Discovery_Of_Witches/Serie_1/S01E01.mkv)
2023-12-12 13:52:46.788 T:2150886 debug <general>: CPlayerGUIInfo::InitCurrentItem(/volume1/Storage0/Video/Series/A_Discovery_Of_Witches/Serie_1/S01E01.mkv)
2023-12-12 13:52:46.789 T:2170321 debug <general>: Loading settings for /volume1/Storage0/Video/Series/A_Discovery_Of_Witches/Serie_1/S01E01.mkv
2023-12-12 13:52:46.790 T:2170355 debug <general>: ScanForExternalSubtitles: Searching for subtitles...
2023-12-12 13:52:46.790 T:2170355 debug <general>: ScanForExternalSubtitles: END (total time: 0 ms)
2023-12-12 13:52:46.790 T:2170355 info <general>: Creating Demuxer
2023-12-12 13:52:46.790 T:2150887 debug <UPNP::BuildObject>: Building didl for object '/volume1/Storage0/Video/Series/A_Discovery_Of_Witches/Serie_1/S01E01.mkv'
2023-12-12 13:52:46.790 T:2170355 debug <general>: Open - probing detected format [matroska,webm]
2023-12-12 13:52:46.790 T:2170355 debug <general>: Open - avformat_find_stream_info starting
2023-12-12 13:52:46.791 T:2170355 debug <general>: Open - av_find_stream_info finished
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: Input #0, matroska,webm, from '/volume1/Storage0/Video/Series/A_Discovery_Of_Witches/Serie_1/S01E01.mkv':
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: Metadata:
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: title : A.Discovery.Of.Witches.S01E01.720p.HDTV.x264-MTB
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: CREATION_TIME : 2018-10-22T07:08:29Z
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: ENCODER : Lavf57.7.2
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: Duration: 00:44:51.14, start: 0.000000, bitrate: 750 kb/s
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: Stream #0:0: Video: mpeg4 (Simple Profile), yuv420p, 720x360 [SAR 1:1 DAR 2:1], 25 fps, 25 tbr, 1k tbn, 25 tbc (default)
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: Stream #0:1(eng): Audio: mp3, 48000 Hz, stereo, fltp, 128 kb/s (default)
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: title : Stereo
2023-12-12 13:52:46.791 T:2170355 info <general>: ffmpeg[0x558ffbc04630]: Stream #0:2(dut): Subtitle: ass (default) (forced)
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDDemuxFFmpeg::AddStream ID: 0
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDDemuxFFmpeg::AddStream ID: 1
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDDemuxFFmpeg::AddStream ID: 2
2023-12-12 13:52:46.791 T:2170355 info <general>: Opening stream: 0 source: 256
2023-12-12 13:52:46.791 T:2170355 info <general>: Creating video codec with codec id: 12
2023-12-12 13:52:46.791 T:2170355 info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDVideoCodecFFmpeg - Updated codec: ff-mpeg4
2023-12-12 13:52:46.791 T:2170355 debug <general>: CVideoPlayerVideo::OpenStream - open stream with codec id: 12
2023-12-12 13:52:46.791 T:2170355 info <general>: Creating video thread
2023-12-12 13:52:46.791 T:2170357 debug <general>: Thread VideoPlayerVideo start, auto delete: false
2023-12-12 13:52:46.791 T:2170357 info <general>: running thread: video_thread
2023-12-12 13:52:46.791 T:2170355 debug <general>: ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: /volume1/Storage0/Video/Series/A_Discovery_Of_Witches/Serie_1/S01E01.mkv
2023-12-12 13:52:46.791 T:2170355 info <general>: Opening stream: 1 source: 256
2023-12-12 13:52:46.791 T:2170355 info <general>: Finding audio codec for: 86017
2023-12-12 13:52:46.791 T:2170357 debug <general>: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: false
2023-12-12 13:52:46.791 T:2170355 info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder mp3float
2023-12-12 13:52:46.791 T:2170355 info <general>: OpenStream: Allowing max Out-Of-Sync Value of 10 ms
2023-12-12 13:52:46.791 T:2170355 info <general>: Creating audio thread
2023-12-12 13:52:46.791 T:2170358 debug <general>: Thread VideoPlayerAudio start, auto delete: false
2023-12-12 13:52:46.791 T:2170358 info <general>: running thread: CVideoPlayerAudio::Process()
2023-12-12 13:52:46.791 T:2170358 debug <general>: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: false
2023-12-12 13:52:46.791 T:2170355 info <general>: Opening stream: 2 source: 256
2023-12-12 13:52:46.791 T:2170355 info <general>: CDVDSubtitlesLibass: Using libass version 1701000
2023-12-12 13:52:46.791 T:2170355 info <general>: CDVDSubtitlesLibass: Creating ASS library structure
2023-12-12 13:52:46.791 T:2170355 info <general>: CDVDSubtitlesLibass: Initializing ASS Renderer
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDSubtitlesLibass: [ass] libass API version: 0x1701000
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDSubtitlesLibass: [ass] libass source: tarball: 0.17.1
2023-12-12 13:52:46.791 T:2170356 debug <general>: Thread BackgroundLoader 140367693338304 terminating
2023-12-12 13:52:46.791 T:2170355 debug <general>: CDVDSubtitlesLibass: [ass] Shaper: FriBidi 1.0.12 (SIMPLE) HarfBuzz-ng 5.2.0 (COMPLEX)
2023-12-12 13:52:46.791 T:2170355 info <general>: CDVDSubtitlesLibass: Initializing ASS library font settings
2023-12-12 13:52:46.806 T:2170355 debug <general>: CDVDSubtitlesLibass: [ass] Using font provider fontconfig
2023-12-12 13:52:46.806 T:2170355 info <general>: CDVDSubtitlesLibass: Creating new ASS track
2023-12-12 13:52:46.806 T:2170355 debug <general>: Created subtitles overlay codec: SSA Subtitle Decoder
2023-12-12 13:52:46.806 T:2170355 debug <general>: CVideoPlayer::SetCaching - caching state 2
2023-12-12 13:52:46.806 T:2170355 debug <general>: CDVDClock::SetSpeedAdjust - adjusted:0.000000
2023-12-12 13:52:46.806 T:2170355 debug <general>: CVideoPlayer::HandleMessages - player 2 reported state: 0
2023-12-12 13:52:46.806 T:2170355 debug <general>: CVideoPlayer::HandleMessages - player 1 reported state: 0
2023-12-12 13:52:46.806 T:2170355 debug <general>: CVideoPlayer::SetCaching - caching state 1
2023-12-12 13:52:46.806 T:2170321 debug <general>: OnAVChange: CApplication::OnAVChange
2023-12-12 13:52:46.806 T:2170357 debug <general>: CVideoPlayerVideo - Stillframe left, switching to normal playback
2023-12-12 13:52:46.806 T:2170357 debug <general>: libva info: VA-API version 1.16.0
2023-12-12 13:52:46.806 T:2170357 debug <general>: libva info: Trying to open /usr/lib64/dri/iHD_drv_video.so
2023-12-12 13:52:46.806 T:2170357 debug <general>: libva info: Found init function __vaDriverInit_1_16
2023-12-12 13:52:46.807 T:2170357 debug <general>: libva info: va_openDriver() returns 0
2023-12-12 13:52:46.807 T:2170357 info <general>: VAAPI::Close
2023-12-12 13:52:46.807 T:2170357 info <general>: VAAPI::Close - closing decoder context
2023-12-12 13:52:46.808 T:2170357 info <general>: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-4 part 2
2023-12-12 13:52:46.808 T:2170357 debug <general>: CDVDVideoCodecFFmpeg - open frame threaded with 16 threads
2023-12-12 13:52:46.808 T:2170357 debug <general>: CDVDVideoCodecFFmpeg - Updated codec: ff-mpeg4
2023-12-12 13:52:46.811 T:2170358 debug <general>: CDVDAudio::Pause - pausing audio stream
2023-12-12 13:52:46.811 T:2170355 info <general>: Skipped 1 duplicate messages..
2023-12-12 13:52:46.811 T:2170355 debug <general>: CVideoPlayer::SetCaching - caching state 2
2023-12-12 13:52:46.811 T:2170355 debug <general>: CDVDClock::SetSpeedAdjust - adjusted:0.000000
2023-12-12 13:52:46.811 T:2170358 info <general>: Creating audio stream (codec id: 86017, channels: 2, sample rate: 48000, no pass-through)
2023-12-12 13:52:46.811 T:2170358 debug <general>: CVideoPlayerAudio:: synctype set to 0: clock feedback
2023-12-12 13:52:46.812 T:2150913 info <general>: CActiveAESink::OpenSink - initialize sink
2023-12-12 13:52:46.816 T:2170357 debug <general>: CRenderManager::Configure - change configuration. 720x360. display: 720x360. framerate: 25.00.
2023-12-12 13:52:46.888 T:2150886 debug <general>: ------ Window Init (DialogBusy.xml) ------
2023-12-12 13:52:46.893 T:2150886 debug <general>: DeleteRenderer - deleting renderer
(full log at https://www.squirrel.nl/pub/xfer/uploads/3Cy4OuUOEHeSadMAZxEKn9bQ.log.gz)
As you can see, the embedded (default, forced) subtitle is correctly detected. It is just not shown by default.
