To add new subtitle fonts. Navigate to your .kodi/media folder. Inside media folder create new folder called Fonts. May need to be capital F.
Then place your new .ttf fonts in this folder. You can then choose which font in kodi settings under video â subtitle. May need reboot to see changes.
To switch between subtitle manually during video playback press letter L.
Iâm using OSMC in a Raspberry Pi 3 and I want to know to can I add to a DVD movie subtitles from my hard disk. A user called fzinken told me âAs long as the srt file has the same name as the video it will automatically be loaded. http://kodi.wiki/view/Subtitlesâ but I want to know how can I add it manually without use any add-on just search it for my own in the hard disk.
Pull up the OSD while media is playing > scroll over to the speaker icon and press select > resulting menu will have an option to browse for subtitle. Itâs all explained in the link quite well.
why donât you just use something like mkvtoolnix to merge your video and subtitle into a single file (after all - this is one of the big advantages of a .mkv container). Then you will never run into the problem of not being able to find the subtitle.
