Subtitles timing +1 sec
hi all,
im using OSMC skin and i would like to move sutitles timing forward about 1 sec, but i cannot find this option anywhere…
in confluence skin it was easy to change timing of subtitles
i have some movie that dont have synchronized subtitles and i need to change the timing.
thanks for help
Hmm, it’s still there. Select the OSD Usually the enter key on your remote. Select the speaker icon on the right side and navigate and select Subtitle Offset. Left and right arrow on your remote +/- the offset.
thanks men, you saved my day… i didnt expect/search it under sound settings
