Sudden wired lan video stutter. All other clients play the same files without problem
Upgraded my win7 server to win10, and suddenly my movies start to stutter and pause every now and then and sometimes making it unwatchable. Using kodi on my Samsung note4 without problems. Plex on ps4 no problem. All from the same server, same file and through the same Asus router. Any help would be highly appreciated!
Also, cat5 patch cable changed just for fun…
I received your message to the Facebook OSMC page and I am sorry we missed this. There were some playback regressions on Vero 2 which caused some stuttering periodically. These have since been resolved. I would recommend you update to the latest version of My OSMC. You can do this via My OSMC -> Updater.
If this persists, then you should enable debug logging, and upload a full set of logs via My OSMC. If you are having problems with one specific type of file, then you can post MediaInfo output so we can look at the file.
My recommendation is to try and play a file that you watched on the Vero before without any problems.
Do you have a Vero 2 or Vero 1?
Vero 1.
Same file as before and has been working perfect until now.
Also, as stated in my previous message, I always have the latest version! Now reading June 2016.06-2
Both testfiles are mkv.
Logging leaves me this link http://paste.osmc.io/emicoyiteg
Document not found…
What to do?
Try and upload the log again and take a photo of the URL if necessary.
I don’t see why you would experience playback issues suddenly, as the Vero 1 has been stable for some time.
You can also try installing an older version of OSMC if you remember a ‘good’ version.
MediaInfo or a small sample of the problematic MKVs may be helpful.
General
Unique ID : 238005888673236322756821076797325218926 (0xB30E444C9653552BA6212239E272946E)
Complete name : F:\9 (2009)\9 (2009).mkv
Format : Matroska
Format version : Version 2
File size : 7.96 GiB
Duration : 1 h 19 min
Overall bit rate : 14.4 Mb/s
Movie name : “Encoded_by_HDBRiSe”
Encoded date : UTC 2009-11-13 17:18:08
Writing application : mkvmerge v2.9.8 (‘C’est le bon’) built on Aug 13 2009 12:49:06
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 16 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 12.9 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.259
Stream size : 6.96 GiB (88%)
Writing library : x264 core 68 r1183M f21daff
Encoding settings : cabac=1 / ref=16 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=9 / psy_rd=0.8:0.2 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=6 / nr=0 / decimate=0 / mbaff=0 / bframes=4 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=12870 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio
Format : DTS
Format/Info : Digital Theater Systems
Mode : 16
Format settings, Endianness : Big
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 1 510 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 spf)
Bit depth : 24 bits
Compression mode : Lossy
Stream size : 856 MiB (10%)
Language : English
Default : Yes
Forced : No
Text #1
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Language : Swedish
Default : Yes
Forced : No
Text #2
Format : ASS
Language : English
Default : No
Forced : No
Text #3
Format : ASS
Language : Greek
Default : No
Forced : No
Text #4
Format : ASS
Language : Norwegian
Default : No
Forced : No
Text #5
Format : ASS
Language : Portuguese
Default : No
Forced : No
Text #6
Format : ASS
Language : Romanian
Default : No
Forced : No
Text #7
Format : ASS
Language : Polish
Default : No
Forced : No
Text #8
Format : ASS
Language : Spanish
Default : No
Forced : No
Text #9
Format : ASS
Language : Danish
Default : No
Forced : No
Text #10
Format : ASS
Language : Hungarian
Default : No
Forced : No
Are you sure that you played this file on a Vero 1 before?
The Blu-ray specification allows for a maximum of 5 reframes. Using 16 reframes is quite excessive. You should ‘source’ your files from a better uploader. It’s out of spec for BD, and increasing the # of reframes will only cause issues.
You may be able to play this on a PC but other devices (ARM) will likely struggle with this. The file is L5.1 which is quite a complex encoding profile.
Hi, and sorry for the late reply. Away on business.
Yeah, well I’m not 100% sure, but let’s do another wich I watch once a year, wich im now unable to play more than little before it looses sound an stutters like crazy.
Mediainfo coming.
The logs I can’t make work.
Complete name : K:\TRON - Legacy (2010)\BDMV\STREAM\00005.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 29.7 GiB
Duration : 2 h 5 min
Overall bit rate : 34.0 Mb/s
Maximum Overall bit rate : 48.0 Mb/s
This is the show I was watching when it happened.
Episode 1 and 2 and then the switch from win 7 -> win10, and then trying to watch ep3.
General
Unique ID : 175441606592584158704567835364155350089 (0x83FCD30970DD101584CFD50A55225C49)
Complete name : I:\Tv-Shows\The Wire\Season 01\The.Wire.S01E03.720p.BluRay.x264-REWARD.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 2.18 GiB
Duration : 55 min
Overall bit rate : 5 681 kb/s
Encoded date : UTC 2015-05-28 00:45:31
Writing application : mkvmerge v7.9.0 (‘Birds’) 32bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : AVC
Format profile : High@L4.1
Format settings, ReFrames : 5 frames
Duration : 55 min
Bit rate : 4 168 kb/s
Width : 1 280 pixels
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.189
Stream size : 1.60 GiB (73%)
Writing library : x264 core 146 r2538 121396c
Encoding settings : cabac=1 / ref=5 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4168 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Audio
Format : DTS
Mode : 16
Codec ID : A_DTS
Duration : 55 min
Bit rate : 1 509 kb/s
Bit depth : 24 bits
Stream size : 594 MiB (27%)
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 53 min
Bit rate : 71 b/s
Count of elements : 691
Stream size : 28.1 KiB (0%)
Title : SDH
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Duration : 53 min
Bit rate : 70 b/s
Count of elements : 678
Stream size : 27.8 KiB (0%)
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:03:55.694 : en:00:03:55.694
00:11:12.213 : en:00:11:12.213
00:19:16.197 : en:00:19:16.197
00:28:27.706 : en:00:28:27.706
00:36:19.594 : en:00:36:19.594
00:43:38.866 : en:00:43:38.866
00:50:22.394 : en:00:50:22.394
00:53:52.020 : en:00:53:52.020
Okay, this last clip should work. So let’s see what’s up.
Enable debugging in System Settings
Reboot
Try to play the clip
When it starts to stutter, press Stop and go to My OSMC -> Logs and upload all logs. Then post the URL here and I will take a look.
Picture to big, here is what was written:
http:/paste.osmc.io/pihinijexe
Please verify the link address again. We see no logs at this URL.
Yeah, what I experienced also, never got a log working.
Rezised the pic.
I can verify Internet connection as I can download subtitles.
Did you find my log now?
There is no log at the URL. It’s just blank. Try again.
Something is not right then, I we been trying at least 5 times, 3 of them to see the log for my self before asking for help. I will se if I can fetch the log from sd card or something.
I have done this several times now, but no log is posted. What to do? How do I manually copy/paste my logs from a win10? I found nothing on the sd card when reading from sd card reader on the computer.
