Hi All,
Until a power cut caused a cold reboot, audio over HDMI worked fine. Now there is no audio coming out, although I checked the Kodi audio system settings and it is still configured to use HDMI. The HDMI cable and AVR are working fine, just tested it with a laptop. What should I check on OSMC to get this going again?
Some settings and logs shown below:
$ amixer
Simple mixer control ‘Master’,0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Limits: Playback 0 - 64
Mono:
Front Left: Playback 64 [100%] [0.00dB] [on]
Front Right: Playback 64 [100%] [0.00dB] [on]
Simple mixer control ‘PCM’,0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control ‘IEC958’,0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control ‘IEC958 Default PCM’,0
Mono: Playback [on]
Simple mixer control ‘IEC958’,16
Mono: Playback [on]
dmesg:
[ 1.908742] ALSA device list:
[ 1.908746] No soundcards found.
[ 1.913271] snd_hda_codec_realtek hdaudioC0D0: ALC889A: SKU not ready 0x400000f0
[ 1.913379] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC889A: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:line
[ 1.913386] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 1.913392] snd_hda_codec_realtek hdaudioC0D0: hp_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 1.913397] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ 1.913403] snd_hda_codec_realtek hdaudioC0D0: dig-out=0x1e/0x0
[ 1.913407] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 1.932420] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input2
[ 1.932608] input: HDA Intel HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1b.0/sound/card0/input3
