Super-noob, access Very 4K+ over network
Just got the Vero 4K+ and am trying to set everything up and have some questions.
First of all, how can I access the internal files of the Vero (in particular keymap and advancedsettings)?
Second, probably connected to that, but how can I copy/move/delete files to the Vero, or a HDD connected to it, from my laptop (Win 10)?
I downloaded Samba from the OSMC App Store, but now what?
Sorry for the very dumb questions, but I have 0 experience with Linux or networking in general. Read through other Samba/SMB threads but they went way over my head.
Easiest is to login via ssh. The files are located at /home/osmc/.kodi/userdata/
This Wiki should help
SSH for control and using WinSCP for transferring Config/addons would be my bet, I wouldn’t use WinSCP for transferring media files though
Thanks a lot guys, could set things up for now and I guess they work. Have only tried SMB v1 for now and will try to get something more secure going later.
However, file transfers seem really slow. Averaging between 1 and 2 MB/s to copy a file to the HDD attached to the Vero. Have a Gbit router set up and the Vero connected to it by Ethernet.
Check your network speed.
Tried what you suggested. This is what I’m getting over WiFI:
Last login: Thu Feb 7 10:36:33 2019 from 192.168.0.14
osmc@osmc:~$ iperf3 -R -c 192.168.0.14
Connecting to host 192.168.0.14, port 5201
Reverse mode, remote host 192.168.0.14 is sending
[ 4] local 192.168.0.19 port 56997 connected to 192.168.0.14 port 5201
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 1.62 MBytes 13.6 Mbits/sec
[ 4] 1.00-2.00 sec 1.75 MBytes 14.6 Mbits/sec
[ 4] 2.00-3.00 sec 1.89 MBytes 15.8 Mbits/sec
[ 4] 3.00-4.00 sec 1.87 MBytes 15.7 Mbits/sec
[ 4] 4.00-5.00 sec 1.87 MBytes 15.7 Mbits/sec
[ 4] 5.00-6.00 sec 1.90 MBytes 16.0 Mbits/sec
[ 4] 6.00-7.00 sec 1.72 MBytes 14.4 Mbits/sec
[ 4] 7.00-8.00 sec 1.78 MBytes 14.9 Mbits/sec
[ 4] 8.00-9.00 sec 1.91 MBytes 16.0 Mbits/sec
[ 4] 9.00-10.01 sec 2.00 MBytes 16.7 Mbits/sec
[ 4] 0.00-10.01 sec 18.5 MBytes 15.5 Mbits/sec sender
[ 4] 0.00-10.01 sec 18.5 MBytes 15.5 Mbits/sec receiver
iperf Done.
osmc@osmc:~$ iperf3 -c 192.168.0.14
[ 4] local 192.168.0.19 port 57003 connected to 192.168.0.14 port 5201
[ 4] 0.00-1.00 sec 2.49 MBytes 20.9 Mbits/sec 0 212 KBytes
[ 4] 1.00-2.00 sec 2.31 MBytes 19.4 Mbits/sec 0 212 KBytes
[ 4] 2.00-3.00 sec 2.14 MBytes 18.0 Mbits/sec 0 212 KBytes
[ 4] 3.00-4.00 sec 1.99 MBytes 16.7 Mbits/sec 0 212 KBytes
[ 4] 4.00-5.00 sec 2.28 MBytes 19.2 Mbits/sec 0 212 KBytes
[ 4] 5.00-6.00 sec 2.24 MBytes 18.8 Mbits/sec 0 212 KBytes
[ 4] 6.00-7.00 sec 2.03 MBytes 17.0 Mbits/sec 0 212 KBytes
[ 4] 7.00-8.00 sec 1.83 MBytes 15.4 Mbits/sec 0 212 KBytes
[ 4] 8.00-9.00 sec 2.27 MBytes 19.1 Mbits/sec 0 212 KBytes
[ 4] 9.00-10.00 sec 2.08 MBytes 17.4 Mbits/sec 0 212 KBytes
[ 4] 0.00-10.00 sec 21.7 MBytes 18.2 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 21.4 MBytes 18.0 Mbits/sec receiver
iperf Done.
And this over Ethernet:
Connecting to host 192.168.0.21, port 5201
Reverse mode, remote host 192.168.0.21 is sending
[ 4] local 192.168.0.12 port 47637 connected to 192.168.0.21 port 5201
[ 4] 0.00-1.00 sec 3.98 MBytes 33.4 Mbits/sec
[ 4] 1.00-2.00 sec 4.49 MBytes 37.7 Mbits/sec
[ 4] 2.00-3.00 sec 4.51 MBytes 37.8 Mbits/sec
[ 4] 3.00-4.00 sec 4.01 MBytes 33.6 Mbits/sec
[ 4] 4.00-5.00 sec 4.40 MBytes 36.9 Mbits/sec
[ 4] 5.00-6.00 sec 4.04 MBytes 33.9 Mbits/sec
[ 4] 6.00-7.00 sec 4.18 MBytes 35.1 Mbits/sec
[ 4] 7.00-8.00 sec 4.08 MBytes 34.2 Mbits/sec
[ 4] 8.00-9.00 sec 4.18 MBytes 35.1 Mbits/sec
[ 4] 9.00-10.00 sec 3.98 MBytes 33.4 Mbits/sec
[ 4] 0.00-10.00 sec 42.0 MBytes 35.2 Mbits/sec sender
[ 4] 0.00-10.00 sec 42.0 MBytes 35.2 Mbits/sec receiver
iperf Done.
osmc@osmc:~$ iperf3 -c 192.168.0.21
[ 4] local 192.168.0.12 port 47639 connected to 192.168.0.21 port 5201
[ 4] 0.00-1.00 sec 3.81 MBytes 32.0 Mbits/sec 0 212 KBytes
[ 4] 1.00-2.00 sec 3.87 MBytes 32.4 Mbits/sec 0 212 KBytes
[ 4] 2.00-3.00 sec 4.04 MBytes 33.9 Mbits/sec 0 212 KBytes
[ 4] 3.00-4.00 sec 3.86 MBytes 32.3 Mbits/sec 0 212 KBytes
[ 4] 4.00-5.00 sec 4.05 MBytes 33.9 Mbits/sec 0 212 KBytes
[ 4] 5.00-6.00 sec 3.74 MBytes 31.4 Mbits/sec 0 212 KBytes
[ 4] 6.00-7.00 sec 3.64 MBytes 30.6 Mbits/sec 0 212 KBytes
[ 4] 7.00-8.00 sec 3.89 MBytes 32.6 Mbits/sec 0 212 KBytes
[ 4] 8.00-9.00 sec 3.83 MBytes 32.1 Mbits/sec 0 212 KBytes
[ 4] 9.00-10.00 sec 3.71 MBytes 31.2 Mbits/sec 0 212 KBytes
[ 4] 0.00-10.00 sec 38.4 MBytes 32.2 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 38.2 MBytes 32.1 Mbits/sec receiver
iperf Done.
Well that would explain your low Samba results as you only get 16 Mbit.
But didn’t you wrote
So I am wondering why you now test via wifi?
Tried both just out of curiosity and to see if it is possible to go wireless in the future.
So what are the iperf3 values for wired? As my understanding is that was your first topic on Samba 1-2 Mbyte?
I posted them above as well. They weren’t great either:
Well 30 MBit is obviously indicating something wrong.
Would suggest to investigate your LAN.
Any pointers? Cause I know basically nothing about networking.
Tried factory resetting the router, did nothing. Checked my cables and they are cat6. So for wired connection, I have no idea what to do.
As for Wifi, changed it to 5Ghz which improved speeds from 19Mbits to around 40MBits, but still not great. No other devices on the network, the Vero is literally next to the router.
Also tried the iperf3 with another PC as well as with my smartphone and the results are about the same
What machine are you testing against? Do you have others to test with?
My PC, my gfs laptop and my smartphone so far.
The results are all very similar to each other, so I guess the problem is not with the Vero but with the router somehow. Maybe try to get my hands on another one to test with.
Can you get both of them connect wired and test between them?
I tried that and got around 90-95Mbits, but figured out why it was so low. Seems like my gfs laptop maxes out at 100Mbits. So I suppose those numbers are realistic.
Next step is to try and get my hands on another router somehow. That must be the source of the problem then, right?
Well if the device only supports 100 Mbit than that is expected.
Well hard to say without knowing all the devices capabilities but gut feel tells something is off there.
Will try that next then.
Thanks a lot for all your help. Much appreciated.
