I have had problems with the supplied Bluetooth Remote since day one. When it is paired, it works fine. The problem is when it loses it’s pairing when it is turned off at the wall, to be moved to another room or taken on holiday.
I have tried unplugging and plugging again a few times, as Moderator grahamh suggests but to no avail.
This time around I moved it into another room and found the remote will not sync. I have tried the official instructions on how to pair the remote to the dongle and, as mentioned by myself in my previous post (in the link) that when I get to the part where I hold the Home & OK buttons for 5 odd seconds, the blue light does not flash. It remains lit solid for approx 30 seconds. I am using a brand new battery. It makes no difference which USB port the dongle is in.
With the blue light staying solid and not flashing, what does it mean?
I see mentions of trying the dongle in either a PC or a PS4. I have both but have not plugged the dongle into anything other than the Vero 4K. I don’t want to cause damage by plugging it into anything else unless instructed to do so by Sam or a Moderator.
Sam. If the dongle has become faulty, can I buy just a replacement dongle or does it have to be the dongle & the remote as one unit?
I plugged the dongle into my PC and it is not recognized. Nothing happens at all. If I plug in a wireless mouse dongle, it appears in the Device Manager as a HID device but the Vero 4K dongle does nothing.
Tried it in the PS4 & Xbox One X, nothing happens at all.
Plugged in the dongle for a Microsoft wireless keyboard and can navigate through the Vero 4K.
I think that the way the Vero 4K remote just gives a steady blue light for about 30 seconds and does not flash, when the Home & OK buttons are pressed, is an indicator of something gone wrong. Why is it doing that?
For your case no need to enable debugging just upload via MyOSMC
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Sam has offered to sell me, at cost, a new remote and its dongle. I think that is very reasonable and ordered one. The Vero 4K, 4K+ and Remotes are now available in New Zealand (where I live) from https://nicegear.nz/ and it would cost me double of what Sam offered (after currency conversion & tax), if I bought it retail from that firm.
The support from Sam & the others here is unsurpassed, in my many, many years of buying consumer products.
Sorry for posting here, moved to another house and lost the usb receiver that came with the remote, is there a way to just buy the dongle without the remote?(don’t need two remotes).
Thanks for the great work.
Vero 4k+ best device I’ve had in a long time.
