Suptronics x400 compatibility
I’d like to buy the Suptronics x400 board (DAC + amp).
Has anyone tried this and can confirm compatibility with osmc?
In a German forum I read that the x400 board didn’t work with osmc in the past.
fyi
The X400 board works even with the latest Krypton build. Though the sound is not as expected (a bit lack of bass).
Hello karower, I do have de X400 board but I can’t figured out how to make it work. Can you help me with this?
Flo
You need to enable the needed dt-overlay in config.txt.
The easiest way to do it is going to myosmc settings and choose in raspberry settings>hardware>soundcard the iqaudio-dacplus overlay. Reboot and select in kodi settings>system>audio the iqaudio-dacplus output.
