hello .
I have a problem my vero 4K works when it is switched off and can no longer be switched on via the remote control. Does anyone have a tip for me? It only helps to disconnect the power. That he boots up again
Thank you in advance LG Holymann
hello .
That is how the vero is designed - to be a 24/7 device. You would need to put device in Suspend mode instead of power-off to be able to turn it back on via remote.
Thank you very much
I didn’t know that. I haven’t had this device that long. LG Holymann
